clock not right problem
I am having difficulty running TestLog 3.0.
The company has purchased license keys, however when I try to start it, I get this error message “Your system clock appears to have been changed, possibly in an attempt to defeat the security system on this program. Please correct your system clock before trying to run this program again. If your clock is already correct, rebooting the system may fix this problem, otherwise contact the author of this program for instructions (report code CCB-A).”
I rebooted the system several times and tried it, but still no luck. The program does not even start to prompt me for the user name and license key.
It is probably important to mention that another user of this machine had ghosted it with an older evaluation copy
i tried emailing your help@passmark.com, but it keeps bouncing back for some reason. any ideas????
thank you
I believe you have emailed me about this issue, i have sent you a fixclock key and instructions on how to use the key.
- You may not post replies
- You may not edit your posts
Forum Rules
