Results 1 to 5 of 5
Thread: V3.0 Build 1004 crashes during database conversion
    Apr 2007
    Rottweil, Black Forest, South of Germany
    4
    Exclamation V3.0 Build 1004 crashes during database conversion
    Just downloaded the Build 1004, installed it and tried to convert a Database from version 2.1 Build 1016.
    =====> During Conversion Testlog crashed.
    Retried several times on two different PCs
    =====> Each time during Conversion Testlog crashed.
    Used another PC, which had still Build 1003 installed
    =====> Conversion worked without any Problem.
    Mar 2005
    912
    A possible crash in the conversion has been fixed in the next build, which should be ready late today or monday.
    Apr 2007
    2
    Default build 1003 db conversion crash
    I am trying to convert a database from version 2.1 build 1013 to version 3.0 build 1003, but the app crashes during the process.
    I can create new databases and populate them without any trouble.
  4. #4
    Mar 2005
    912
    Could you please try this build http://www.passmark.com/ftp/testlog3.0.1005-a.exe, the conversion problem should be fixed. The proper build should be ready tomorrow.
  5. #5
    Apr 2007
    2
    That fixed it! Thanks very much.
