Results 1 to 3 of 3
Thread: Customised fields not available in Web Access
    Mar 2007
    Switzerland
    11
    Exclamation Customised fields not available in Web Access
    I have experienced a problem with the customised fields "Test Types" and "Test Phases". I have customised the types and phases in TestLog.
    In the Web Access, my customised types and phases are correct in the readonly view. However, in the edit view, the pull-down menus show the original values for the types and phases. My customised values do not exist.
    In addition, I came across a problem with the field notes 1 and 2. It works fine in TestLog, but in the Web Access, the test case pages (edit and readonly) do not show the heading for the text fields.
    I am using TestLog version 3.0 build 1002.
    Mar 2005
    912
    This will be fixed in the next release, which should be ready in the next day or two, the file that stores the customised values isn't being opened correctly by the web version so the the only values available are the original values.
    Mar 2007
    15
    Question
    Quote Originally Posted by gseeli View Post
    I have a problem with the notes fields also. I renamed my notes fields 1 and 2 to "Clarifications" and "Test Data," respectively. When I view my project test cases in Test Log (under the Project Test Cases folder), those customized headings are displayed correctly. But when I create a test detail report, it shows "Notes Field 1" and "Notes Field 2" instead. I just installed build 1003 this morning and am still having this issue.
