Results 1 to 3 of 3
Thread: Windows XP & WirelessMon problem...
    Mar 2007
    1
    Red face Windows XP & WirelessMon problem...
    Hello.
    I just downloaded trial version of WM, and it won't run.
    I see in "Processes" WirelessMon.exe but, I can't see it on my Desktop.
    What to do?
    I have Win XP + SP2.
    4,143
    Mar 2005
    912
    Is the icon displayed in the system tray? Are you able to select the "show main window" option from the system tray?
    You can also try deleting your configsetup.ini file in the WirelessMon directory to force all the settings to default values and then try opening WirelessMon again.
