Run multiple disk drive test modes consecutively
I want to be able to run multiple disk drive test modes consecutively, select the modes I want to run and number of cycles and then have it go from one to the next looping until I stop it.
For a particular hard drive, you can either select one of the 9 test modes, or you can choose to cycle through all of the test modes in a sequential manner. You can't select a subset of between 2 and 8 modes to cycle on a single drive.
If you have multiple hard drives you can select different modes per drive.
Another solution might be to partition the hard drive and then you can run different modes simultaneously on the same drive.
- You may not post replies
- You may not edit your posts
Forum Rules
