Results 1 to 2 of 2
Thread: Using Variables
    Feb 2007
    2
    Lightbulb Using Variables
    Hi there,
    Running from a memory stick, I would like to set the log files and certificate to save to the desktop of the currrent user. I have tried to use system variable like %USERPROFILE%\Desktop\filename
    But this still does not work, instead it creates a called %USERPROFILE% in the burintest directory on the USB disk.
    I am actually using the USB disc to pretest what will ultimatley be put on CD.
    Any ideas?
    Feb 2004
    742
    The current version of BurnInTest does not expand the environment variables for the log file name. You will need to specify the directory path.
    We will add to our list of possible future features to expand environment variables from the log file name.
    Ian (PassMark)
