Results 1 to 4 of 4
Thread: interpet the hard drive test
    Aug 2006
    North Georgia
    5
    Default interpet the hard drive test
    I ran the performance test several times changing things around. I have 2 250Gb SATA 3.0gb drives. I was shocked at my results. Mine a Intel GNT945 vs. the about the same thing sample from passmark. Read, mine=40.9 theirs=605.9 Write, mine=41.5 theirs=5.9 RW, mine=4.5 theirs=105.2. I thought I was supposed to have about the fastest drives around. What is the problem? Surely it isn't because I have such large drives? What can I do?
    I have been in the Low Voltage Field for 25 years. Now I am specializing in the Video Surveillance field. I assemble all my DVR's using only PC based systems. I will be happy to answer any questions when I have time. Good Day!
    4,143
    You need to look at a cross section of results to get an idea about what is typical. Not just one machine.
    Are your drives running in RAID 0 config?
    Even if the SATA interface is 3.0Gbit/sec, it doesn't matter. Hard drives are not usually limited by the interface speed. 0.5Gbit/sec is probably enough.
    The machine you compare yours to might have been running with a very large cache. Or it might have even been a RAM disk.
    Highly unlikely.
    15K RPM drives in RAID 0, with perpendicular recording & 4Gbps Fibre Channel interfaces are around the best gear at the moment. This doesn't sound like what you have.
    Aug 2006
    2
    Default HardDrive Test is not working any correct
    I have on my System a 10,000 RPM Raptor / Board DFI Lan Party 875pro with on board SATA / no Raid.
    The tests says it has ONLY 3.2 MegaByte Read speed....
    same with the other Hard Drive Tests results with this PC/Drive.
    All show way to low. In fact my old laptop shows faster HartDrive results.
    I assume there is something wrong with this test software....
    ...or do I miss something?
  4. #4
    4,143
    If you are getting only 3.2MB/sec there is somethng wrong with your system. You should get about 40MB/sec.
    Check the cables, BIOS, free space, disk fragmentation, mother board device drivers and any background tasks that might be using the hard dive at the same time as your tests.
Similar Threads
  1. Butterfly hard drive test
    By Glenn in forum BurnInTest
    Last Post: 04-13-2006, 02:53 PM
  2. BurnIn Test; Saved Log. Hard Drive Info
    Last Post: 02-03-2005, 12:38 AM
  3. Hard Drive results?
    Last Post: 01-05-2004, 11:19 PM
  4. hard drive scores are way to bad?
    Last Post: 11-23-2003, 10:28 PM
  5. interpet the hard drive test
    By keith1961 in forum General
    Last Post: 12-31-1969, 11:29 PM
