Results 1 to 3 of 3
Thread: Sluggish Laptop ?
    Aug 2006
    2
    Default Sluggish Laptop ?
    Hi all . What do you make of this configuration , and Norton 6.0 Performance Test's verdict ?
    Intel centrino Pentium M 1.73ghz , 2mb cache , 533
    1gb ddr ram 533 , PC 4200
    80 gb hard drive , 5400 rpm
    256 mb geforce go 7800GTX
    1680X1050
    RESULT = 420
    ( My System info says only 565 out of the 1000 memory is available .....)
    4,147
    420 is a good result for a 1.7 Pentium M. Other Pentium M's around this speed get overall PassMark ratings of 290 - 350.
    If the machine is sluggish then is probably isn't becuase of the hardware. More likely the problem is with some softwre you have running.
    It is normal that not all your RAM is available. A big chunk will be used by the disk cache (when nothing else requires it).
    Aug 2006
    2
    many thanks for the input
Similar Threads
  1. Video test Crashes Dell Laptop
    By Professoran in forum Other software
    Last Post: 07-12-2006, 01:44 AM
