Results 1 to 7 of 7
Thread: Access Violation at 0x7c901095
    Jul 2006
    4
    Default Access Violation at 0x7c901095
    thats what I get with burnin test 5.1....
    this is a sytem I just built, athlon 3800 x2 64
    asus A8N-SLI mobo
    2 Gig Corsair dual channel ram
    it seems to run well but fails the burn in tes and the performance test...
    any help would be much appreciated.
    Thanks.
    Plick.
    4,143
    It is almost sure it is this problem,
    http://www.passmark.com/forum/viewtopic.php?t=383
    Which as detailed above, turned out to be a bug in the Windows O/S. Microsoft issued a patch which should fix it.
    But we are also aware of another problem 'Access violation at 0x7566420B...' which we believe is related to a bug in nVidia video card device drivers before V65.20.
    Jul 2006
    4
    I did the hotfix....now I can do the performance test ok but I still get the error when trying the burn in test...
    I have the invidia 7300, with 8.3.9.1 version drivers.
    4,143
    Can you,
    1) Tell us all the details, including the exact crash address and the module name if it appears. I would be surprised if the crash address was the same for both issues.
    2) Run one test at a time in BurnInTest to narrow down the particaular test causing the problem. The 3D and 2D video tests cause the most problems in general. Almost every video card device driver released in the last 5 years has had bugs in it. And the situation is even worse with SLI video.
  5. #5
    Jul 2006
    4
    Video seems fine, when testing audio I went bluescreen.
    there is definitly a problem with my soundblaster audigy 2.
    still testing
    Jul 2006
    4
    It appears I have found the problem, apparently I had the driveres loaded for the asus onboard sound (even though it was disabled) and it caused a conflict with the audigy sound card drivers....
    Thanks for the help.
  7. #7
    4,143
    Thanks also for posting details of the solution. It is always good to get to the bottom of these issues.
Similar Threads
  1. cpu error access violation at 0x7c91084b dual core
    By jniles in forum PerformanceTest
    Last Post: 08-29-2006, 04:42 AM
  2. Access points list is empty
    By lightfoot in forum WirelessMon
    Last Post: 06-23-2006, 12:19 AM
  3. PerformanceTest could not access system management bios info
    By plmanikandan in forum PerformanceTest
    Last Post: 06-21-2006, 04:16 AM
  4. Athlon 64 Multiple Process Test Disk Access Performance
    By RandySavage in forum PerformanceTest
    Last Post: 11-11-2005, 05:14 AM
  5. Replies: 1
    Last Post: 01-23-2003, 11:12 PM
