Any idea what might cause this error? The .bitcfg was set to run for 12 hours and halt on the first error. It appears that it ran the full 12 hours, then halted with this strange error. I've snipped out the irrelevant SMART data.
Thanks.
PassMark BurnInTest Log file - http://www.passmark.com
BurnInTest V5.1 Pro 1011
Logging detail level: Normal
SYSTEM INFORMATION
Network Name: LE363-EVAL
Date: 07/21/06 10:24:17
Operating system: Windows XP Professional Service Pack 2 build 2600
Number of CPUs: 1
CPU manufacturer: Geode by NSC
CPU type: 586 Gen
CPU features: MMX 3DNow!
CPU1 speed: 400.0 MHz
CPU L2 Cache: Unknown
RAM: 503 MB
Video card: Advanced Micro Devices Windows Graphics Driver (Resolution: 1280x1024x32)
Disk drive: Model HEJ423020F9AT00 (Size: 18.6GB)
Optical drive: TOSHIBA CD/DVDW SD-R6472
DETAILED EVENT LOG
LOG NOTE: 2006-07-21 10:24:17, Status, PassMark BurnInTest V5.1 Pro 1011
LOG NOTE: 2006-07-21 10:24:18, Status, Main Tests started
LOG NOTE: 2006-07-21 10:24:23, Disk, Drive C: SMART attribute data
LOG NOTE: 2006-07-21 10:24:25, Disk, Model HEJ423020F9AT00, Serial# 5J3722
LOG NOTE: 2006-07-21 10:24:25, Disk, Power on hours count: 13745
LOG NOTE: 2006-07-21 10:24:26, Disk, Power cycle count: 76
LOG NOTE: 2006-07-21 10:24:26, Disk, Temperature: 33C
LOG NOTE: 2006-07-21 10:24:26, Disk, All other SMART attributes within thresholds.
LOG NOTE: 2006-07-21 10:49:16, Disk, C, SMART Reallocated Sector
[SNIP more SMART data]
LOG NOTE: 2006-07-21 22:15:41, Disk, C, SMART Reallocated Sector Count start value: 0, current value 0
WARNING : 2006-07-21 22:24:24, CPU - Maths, No operations reported in timeout period
LOG NOTE: 2006-07-21 22:24:24, Status, Test run stopped
RESULT SUMMARY
Test Start time: Fri Jul 21 10:24:17 2006
Test Stop time: Fri Jul 21 22:24:18 2006
Test Duration: 012h 00m 01s
CPU - Maths 12 -40063254 FAIL 1 No operations reported in timeout period
CPU - SIMD 29 1.008 Billion PASS 0 No errors
Memory (RAM) 64 44.929 Billion PASS 0 No errors
2D Graphics 278 278798 PASS 0 No errors
Disk (A: ) 1883 576 Million PASS 0 No errors
Disk (C: ) 29 6.122 Billion PASS 0 No errors
Network 1 756 6.053 Million PASS 0 No errors
CD/DVD (D:) 21 14.736 Billion PASS 0 No errors
Sound 283 478 Million PASS 0 No errors
Parallel Port 4 1.252 Million PASS 0 No errors
Serial Port 1 384 22.118 Million PASS 0 No errors
Serial Port 2 380 21.906 Million PASS 0 No errors
TEST RUN FAILED
SERIOUS ERROR SUMMARY FOR THE LAST TEST RUN
