I am having serious problems testing units with 2 NICs. Typical unit has a Wireless card and an Ethernet NIC.
I read carefully the help file on "advanced" + FAQ and still can't understand if ONE Endpoint is enough or if you need one per NIC. I find the documentation unclear on that point...
In any case, I have ONE Endpoint running and ONE computer on a local network. Endpoint runs on a computer that does nothing else.
When I start the network test with BOTH NIC enabled nothing happens. Data Sent and received by both cards is zero and EndPoint doesn't seem to see anything.
CheckEnd displays the name of computer running EndPoint!
Only way to have the test run is to disable one of the NIC by right clicking on systray Icon and selecting "disable".
Am I missing something or BurnInTest can't do that? I am not really interested in writing another plugin for network testing...
Thanks in advance for any info.
Mad*
screen of unit under test here (ORION-HT is running EndPoint)
