Originally Posted by
Faderz
Just a thought but have you checked the setings in your bios? This isn't necessarily related to Performance Test, but just in general memory timeings and how you are acheiving your clock are pretty important. 2ndly look for any programs running in the background. I was mystified by my low scores for about 2 days only to find out that I was folding and didn't realize it (DOH). I'm sure you're doing it but double check your performance before you run any software. Go in and kill any of the messengers, etc before you run it. Alternatively check for patches to any software you are running as you may have a memory leak that is killing your performance. Hope it helps.
Mike
3800+ X2
MSI K8N Nforce4 SLI PLatinum
2X 512 MB DDR400 Ram
2 WD 120GB SATAII + 2 Hitachi 80 GB SATAII
in a 4 channel raid 0 array
Antec Truepower 2.0 550Watt PS
Samsung SyncMaster930B 19
