we used BIT4 and now BIT5. Unfortunately we encounter problems while saving the configuration files with the new version.
If we load them after saving, some tabs are switched back to standard values (eg. Sound; Logging; RAM; ...). This will cause much extra work on our site! Also some configurations default values seems not to work -> Logging "Max File size" = 0!
Can you please advise, if this is a general problem? We use four different systems until yet, all with the same problem.
br
EKF
