Results 1 to 2 of 2
Thread: Compare Hash Sets
    May 2012
    1
    Default Compare Hash Sets
    Is there a way to compare Hash sets? For example I downloaded the WinXPsp3 hash from the downloads section and I would like to compare that to my PC's hash set I that I created. Is that possible? Or do I have to manually check that?
    4,143
    One way of doing it it to use the File Name Search function to bring up a list of all files in, for example, in your C:\windows\system32 folder.
    Then press CTRL-A on the keyboard to select all items in the list of files. Then right click and select Look Up In Hash Set.
    You can then sort the list by files in and out of the hash set, from the Sorting drop down selection list.
