Results 1 to 5 of 5
Thread: Temperature Monitoring
    Mar 2006
    7
    Default Temperature Monitoring
    I am trying to use BITPro 5 and Hmonitor 4.2.14 pro to produce test certicates but cannot get hmonitor data into bitpro as I cannot choose the sensor ( nothing in drop down box). Is there any thing else I have to do to get the progams talking to each other
    Mar 2006
    7
    Default Temperature monitoring
    Further to my post, have tried speed fan which displays temps fine while test as running but does retain display info when tests end.
    Feb 2004
    742
    I have contacted Alexander Berezkin from Hmonitor and he has asked that you contact him with and supply a hardware report from Hmonitor.
    support [at] hmonitor.com
    We will investigate the Speedfan issue reported shortly.
    Best regards,
    Ian
  4. #4
    Mar 2006
    7
    Registered for the beta program with hmonitor, - current beta version fixed that issue- BUT as I am trying to add temperture to my end of repair test burn in speedfan seems a better solution if BITPro would retail result not just display while testing otherwise I will have install ans register a copy of hmonitor for every repair??
  5. #5
    Feb 2004
    742
    The temperature readings are written to the log file at the end of a test, so in this sense they are retained or usable after the test completes. For example a Normal level log file will contain a Result summary with the temerature readings at the end of the test, as follows:
    RESULT SUMMARY
    Test Start time: Mon Mar 20 10:39:52 2006
    Test Stop time: Mon Mar 20 10:40:00 2006
    Test Duration: 000h 00m 08s
    Temperature Sensor 1 (Min / Current / Max): 49.0 / 49.0 / 49.0
    Temperature Sensor 2 (Min / Current / Max): 43.0 / 43.0 / 43.0
    Temperature Sensor 3 (Min / Current / Max): 46.0 / 46.0 / 48.0
    CPU - Maths 1 100 PASS 0 No errors
    TEST RUN PASSED
    Does this meet your requirement, or do you really need it to display this on the main Window?
    Best regards,
    Ian
Similar Threads
  1. Information request for temperature testing
    Last Post: 02-25-2004, 01:50 AM
