Results 1 to 3 of 3
Thread: BIT 6 - Optical Drive Burn Test
    Nov 2010
    40
    Default BIT 6 - Optical Drive Burn Test
    I'm currently only using the read test for the optical drive, but they want me to change it to the write test.
    I was curious though, does it make a difference if we write a CD or DVD. I noticed that Passmark has the option to do both.
    If we only do one, would that be a sufficient benchmark on whether or not the optical drive is able to burn disks in general? I just don't want to burn a CD and find the optical drive isn't able to burn DVDs and so on.
    As far as I understood though, if it's able to burn one type of disk, it's able to burn all that it's capable of.
    4,143
    In 99% of cases, if a one format can be burnt then the other one will also be OK.
    I would do a DVD rather than a CD, because 1) DVDs are now more common and 2) Track spacing etc.. is finer on a DVD so more precision is required.
    Nov 2010
    40
    Quote Originally Posted by passmark View Post
    Perfect. Thanks for the information.
