Results 1 to 5 of 5
Thread: Unknown Directx Error
    Oct 2011
    3
    Default Unknown Directx Error
    Hi there,
    Recently I have been experiencing problems while playing Starcraft 2. During the game my screen will start to artifact and than my computer will restart. I have tried several different drivers, Reformatted, monitored all my temperatures bought a new heatsink for my cpu, and no results I ran the BurnInTest 7.0 and it failed the 3d test due to "Error initializing DirectX device" and "Unknown DirectX error". I wish i could figure this out.
    My system specs:
    Code:
    System summary:
    Windows 7 Service Pack 1 build 7601 (64-bit),
    1 x Intel(R) Core(TM)2 Quad CPU Q6700 @ 2.66GHz,
    4.0GB RAM,
    NVIDIA GeForce GTX 560,
    56GB HDD, 233GB HDD,
    CD/DVDRW,
    General:
    System Name: ROSS-PC
    Motherboard Manufacturer:  EVGA
    Motherboard Name: 132-CK-NF78
    Motherboard Version: 2
    Motherboard Serial Number: 1
    BIOS Manufacturer: Phoenix Technologies, LTD
    BIOS Version: 6.00 PG
    BIOS Release Date: 03/24/2008
    CPU:
    CPU Type: Intel(R) Core(TM)2 Quad CPU Q6700 @ 2.66GHz
    Codename: Kentsfield
    CPUID: Family 6, Model F, Stepping B, Revision G0
    Socket: LGA775
    Lithography: 65nm
    Physical CPU's: 1
    Cores per CPU: 4
    Hyperthreading: Not capable
    CPU features: MMX SSE SSE2 SSE3 SSSE3 DEP PAE Intel64 VMX
    Clock frequencies:
    -  Measured CPU speed: 2667.2 MHz
    -  Multiplier: x10.0
    -  Scalable Bus Speed: 267.7 MHz
    -  Front Side Bus: 1066.9 MHz
    Cache per CPU package:
    -  L1 Instruction Cache: 4 x 32 KB
    -  L1 data cache: 4 x 32 KB
    -  L2 cache: 2 x 4 MB
    -  L3 cache: Not applicable
    Memory
    Total Physical Memory: 4095MB
    Available Physical Memory: 2878MB
    Memory devices:
       A0:
       - DRAM, 1024MB, 800MHz,
       A1:
       A2:
       A3:
    Virtual memory: C:\pagefile.sys (allocated base size 4094MB)
    Graphics
       Chip Type: GeForce GTX 560
       DAC Type: Integrated RAMDAC
       Memory: 1024MB
       BIOS: Version 70.24.18.0.60
       Driver provider: NVIDIA
       Driver version: 8.17.12.7533
       Driver date: 5-20-2011
       Monitor 1: 1680x1050x32 60Hz (Primary monitor)
    Disk volumes
    A:  Floppy
    C:  Local drive, NTFS, (55.90GB total, 22.85GB free)
    D:  Local drive, NTFS, (232.79GB total, 232.33GB free)
    E:  Optical drive
    Disk drives
    Disk drive: Model OCZ-VERT EX3 SCSI Disk Device (Size: 55.90GB)
    Disk drive: Model ST325031 0AS SCSI Disk Device (Size: 232.88GB)
    Optical drives
    E: HL-DT-ST DVD-RAM GH22LS30 (CD/DVDRW)
    Network
    NVIDIA nForce 10/100/1000 Mbps Ethernet
    NVIDIA nForce 10/100/1000 Mbps Ethernet (Speed: 1Gb/s)
    Atheros AR5005GS Wireless Network Adapter (Speed: 54Mb/s)
    Ports
    Communications Port: COM1 - RS232 Serial Port (max Baud rate: 115200)
    Keyboard Port: PS/2  connector
    Mouse Port: PS/2  connector
    USB
    Standard OpenHCD USB Host Controller
       - Logitech G9 Laser Mouse (SN: F0EAEBBD000029)
       - G15 Gaming Keyboard
       - G15 GamePanel LCD
    Standard Enhanced PCI to USB Host Controller
    Thanks for all your help!
    -Ross
    Feb 2004
    742
    I would suspect your Graphics card device driver or hardware is failing causing Windows to crash. I would make sure this driver is updated and if possible try a different video card.
    I would set Windows to not automatically restart on failure so you can see the Blue Screen Of Death diagnostic screen as this often shows the device driver in question:
    Control panel->System->Advanced tab, Startup and recovery, Settings, Uncheck "Automatically restart".
    You should check the system event log for the crash event - this may tell you something useful.
    If you know how to analyze the Windows\memory.dmp file, I would look at the stack trace in this. If not and it is not enormous, then you can email it to us and I can take a look. Our email address is here:
    http://www.passmark.com/support/index.htm
    Oct 2011
    3
    Thanks for your help! I have tried my old 8800gt which use to work. and i had the same issue although i never ran that through BurnInTest.
    Next time it happens i will send you my memory.dmp file.
    Thanks,
    Ross
  4. #4
    Oct 2011
    3
    So i switched out the GPU for a known working one and i am still getting the same error. Any suggestions?
  5. #5
    Feb 2004
    742
    Specifically for the unknown DirectX error reported in BurnInTest, you can email us a level 2 trace file of the test run showing the error and we will have a look at it for clues. A level 2 activity trace file is configured in Preferensces->Logging.
    Also, as mentioned I would check for clues as follows - what did these tell you about the system crash:
