This test was ran on my new design system at home. It stayed at 34C the whole time..If I did a couple more tests over it would be higher. Plus i'm going to go with the GeForce 7800 that will make go higher to.
Score=1114.5 Whatchuuuu Think?
System
Windows Xp Professional x64 Bit Edition
AMD Athlon 64 X2 4200+/2MB Cache / 2000MHz FSB/Dual-Core
Aerocool GT-1000 Gold Plated Heatpipe CPU Cooler + 1,800 RPM 92x25mm Fan
Asus A8N SLI Premium Socket 939 ATX Motherboard
Ultra / X-Connect / 500-Watt / Dual 80mm Fan/ Titanium-Black/ Power Supply
Creative Labs Sound Blaster Live 5.1 Sound Card Front Panel Control
ATI Radeon X700 / 256MB DDR2 / PCI Express / DVI / VGA / TV-Out / Video Card
4 GB Corsair Dual Channel PC3200 DDR 400MHz Memory
4 Blue Ultra DDR Aluminum Memory Coolers
2 18" Translucent Blue 7 Pin Serial ATA Drive Cable
2 Seagate / 160GB / 7200 / 8MB / SATA-150 Drives
1 External Samsung 160GB/7200/8mb/IDE-Drive
2 Vantec Vortex Hard Drive Cooling Systems
2 Aopen 19-Inch / 16ms / SXGA / Black / DVI-VGA / LCD Monitors
1 Samsung TS-H552U DVD-Burner
1 LG 52x 32x 52x CD Writer
2 Ultra Dual 12" Cold Cathode UV Light Kits
WinTV 878 PCI TV Tuner Card
Thermaltake Cigarette lighter & Beverage tray
Thermaltake Black Kandalf Full-Tower AXT Case
