Results 1 to 2 of 2
Thread: RAM Test - Question
    Aug 2011
    12
    Default RAM Test - Question
    Using Windows 7 WinPE BurnInTest V6 Pro, I ran a 24 Hr memory torture test and it completed with no errors. The server and BurnInTest was seeing 32 GB's of RAM.
    However, the BIOS event logger showed "Single-Bit ECC Errors in DIMM#1B". Essentially it turns out that DIMM #1B is a bad slot. Why would the software still detect the memory for that slot and pass with no errors?
    Also, if I use the memory torture test does that include the same tests from the standard test? Should both tests be run?
    4,147
    ECC RAM - Error Correction Code can detect and correct errors.
    So it looks like your RAM detected and corrected an error. As it should.
    And because the error was just a single bit the fault could be corrected at a low level with no consequence. So the operating system and any applications running will never detect any error (as there was no error, at a high level).
    Should be no need to run both tests in general usage.
