Results 1 to 5 of 5
Thread: Linux missing library
    May 2009
    12
    Default Linux missing library
    Hello all.
    When I try to run Passmark in a Debian based Linux computer (via terminal), it returns me missing library.
    So using dd command, I get:
    libxcb-xlib not found message
    Do you know what package includes this missing library?
    Using Synaptic I see many libxcb-XXXXX references (some are installed and some others are not), but I don't know which one to install so I can run Passmark's B.I.T.
    Can someone help?
    Thank you.
    xpto
    4,145
    There is a section in the FAQ about missing libraries,
    http://www.passmark.com/support/bitlinux_faq.htm
    May 2009
    12
    Quote Originally Posted by passmark View Post
    Hello.
    Hum... read it. There's nothing specific to libxcb-xlib.
    Any more suggestions?
    Thank you
  4. #4
    Mar 2005
    912
    You should just need the libxcb package, possibly listed as libxcb1 in synaptic (this is how it appears in Ubuntu). The development environment we're using has libxcb - 1.2-5 though a newer version should be fine as well.
    Was this the only missing library reported by ldd?
  5. #5
    May 2009
    12
    Quote Originally Posted by TimR View Post
    Hello Tim.
    Thank you for your answer.
    libxcb was the only library missing (I also thought it was strange, because normally many more libraries are missing - ie:when KDELibs is absent, this produces several libraries missing messages).
    But I'll try your suggestions and then get back to you.
    Thank you so much.
    xpto
