Results 1 to 2 of 2
Thread: OSFMount does not mount split raw images
    Jun 2011
    1
    Default OSFMount does not mount split raw images
    I have an image created as split raw files. All files are correctly named with incrementing extensions (eg: .001, .002 ... .035)
    When I mount the image using OSFMount I only get a 2GB image based on the .001 split file.
    Any insight into what I'm doing wrong?
    Thanks!
    Oct 2010
    22
    What program did you use to create the split image files?
    What partitions are contained in the image? How big are they?
    Did OSFMount correctly detect the image as "Split Raw Image"?
