Results 1 to 2 of 2
Thread: help with video card and motherboard
    Mar 2011
    1
    Default help with video card and motherboard
    im looking at get this http://www.newegg.com/Product/Product.aspx?Item=N82E16883229252 computer but if i did i would put in this http://www.newegg.com/Product/Product.aspx?Item=N82E16814150447&cm_re=Radeon_HD_ 5770-_-14-150-447-_-Product video card in will it work in that computer with out killing it or something do to Compatibility problems in the chip’s (motherboard vs the video card or any of it) ?
    4,141
    Should be OK.
    But the machine has a nVidia motherboard (NVIDIA GeForce 7025). So you can be sure that nVidia video cards would be been better tested with this motherboard.
    The 5770 needs at least a 450W power supply. But this should be OK.
    The only other concern might be heat in the case and space in the case.
