Results 1 to 3 of 3
Thread: Motherboard? X6 1090T
    Mar 2011
    1
    Default Motherboard? X6 1090T
    Ive decided to build my own PC(first timer), and i need to know what motherboard to choose.
    Ive decided on going with the phenom II x6 1090T cpu.
    If possible, what motherboard(s) were used in testing the benchmarks for the 1090T?
    4,141
    You can use PerformanceTest to view the componets used for each result.
    As of today there are more than 2800 results that have the 1090T CPU.
    Some motherboards include,
    ASUS M4A88T
    ASUS M4A87TD
    Gigabyte GA-890GPA-UD3H
    Oct 2007
    234
    As long as you stick with Asus, Asrock, Gigabyte or MSI brand boards you should be in ggod shape. Just make sure the board you choose supports the six core CPU's and is a DDR3 board. USB 3 and SATA 3 (6 Gb/s) support would be a good idea also as its more future proof. The most important parts in any PC are the memory and power supply so do not skimp on either. For memory I stick with Corsair or Crucial when possible. For Power supplies Corsair or Seasonic. If you can give us an idea of what you want to use the PC for, how much you have to spend and a list of the components you were looking at we can be more specific with recommendations.
    Bill
    Main Box*i7 930*GA X58A-UD3R R2*3x4 gig Patriot DDR3 1600EL*EVGA GTX 460 1 gig*Intel X25-M G2 80 gig*WD Green WD20EARS 2 TB*ASUS DRW-24B3LT*Samsung SH-S223L*Corsair AX750 PSU*Rosewill Challenger case*Windows 7 Ultimate 64 bit SP1
