Results 1 to 4 of 4
Thread: [OSFClone : REQ] Need more informative display while imaging process
    Feb 2011
    2
    Default [OSFClone : REQ] Need more informative display while imaging process
    I am very impressed with the ability of OSF and I have tried it. However, I need a more detailed look at the hard disk cloning. It is very important to me for forensic results can be used in court.
    IMHO, it will be simply like this:
    DATE : MM/DD/YYYY
    OPERATION : IMAGE COMPLETE DRIVE (All Partitions)
    FILE NAME : image.img
    __________________________________________________ ___________
    | SOURCE | DESTINATION |
    | DRIVE : /dev/sda | DRIVE : /dev/sdb |
    | SIZE : 156.4GB | SIZE : 499.4GB |
    | SERIAL NUMBER : xxxxxxxx | SERIAL NUMBER : xxxxxxxx |
    | CHECKSUM : xxxxxxxxxxxxxxxxx | |
    START TIME : hh:mm:ss
    Imaging...
    Finished : hh:mm:ss
    IMAGE CHECKSUM : xxxxxxxxxxxxxxxxx
    GBU.
    Thank you for your feedback. There is currently an option to save a log after imaging stored in the same location of where the image file is saved. The log does contain the majority of the information you mentioned.
    However it is unclear on the exact request,
    Do you feel the result log is lacking on information and needs to be expanded?
    or
    As stated, in the thread topic, that more information is needed during/while the image is being created?
    Feb 2011
    2
    I mean, "that more information is needed during/while the image is being created".
  4. #4
    4,141
    What information would you like to see?
