Results 1 to 7 of 7
Thread: TL_TGLIST Customization
    Oct 2008
    6
    Default Add customize
    Can I add more columns in the Project Test Case
    The TGLIST tag can be edited to change the columns that are used for displaying the list and in what order. You can select which columns to add by playing the appropriate heading tag for an item to the tag between "::", eg <!--TL_TGLIST:TL_TITLE_HEADING:TL_TESTTYPE_HEADING:TL_ TESTTPHASE_HEADING:TL_STATUS_HEADING:--> will display the ID, title, test type, test phase and test status for the list of project test cases. Only items that were part of the original list can be used.
    Is there a way to add more items to the original list?
    Oct 2008
    6
    Default TL_TGLIST Customization
    Is there a way to add the items to the original list?
    Mar 2005
    912
    Only the fields that are displayed in the matching TestLog standalone list view can be used, eg when listing the contents of a test suite you can use;
    ID (TL_ID_HEADING)
    Title (TL_TITLE_HEADING)
    Priority (TL_PRIORITY_HEADING)
    Expected Duration (TL_EXPDURATION_HEADING)
    Type (TL_TESTTYPE_HEADING)
    Phase (TL_TESTTPHASE_HEADING)
    Updated Date (TL_UPDATEDATE_HEADING)
    Author (TL_AUTHOR_HEADING)
    Configurations (TL_CONFIG_HEADING)
    Resources (TL_RESOURCE_HEADING)
  4. #4
    Oct 2008
    6
    Smile
    So there is no way I can added other such as External Description Link
    from the test Case? can I customize the Standalone to add that so that I can see on the html reports
  5. #5
    Mar 2005
    912
    Currently no, feilds that aren't already being displayed cannot be added to the list views.
  6. #6
    Oct 2008
    6
    Smile
    Can I change the Requirement field in Test case to accept Hyderlink, because if I do that it is displaying the report as just as text.
    And secondly are you planning in future to add more fields to <TG_LIST>
  7. #7
    Mar 2005
    912
    The requirements field isn't currently processed before display to automatically convert hyperlinks, so entering http://www.test.com won't be translated to a clickable link.
    As a workaround you can however add the web address as HTML in the field and it will be displayed as a hyperlink, eg <a href=http://www.test.com>Test</a>.
    We'll look at which new fields could be added to the listview display and <TG_LIST> for the next major version.
