Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Fidelity problem on Windows 7 if sample rates do not match.
  1. #11
    Jan 2011
    3
    Thanks for the help. I rebooted and the device drivers apparently were detected and I thought they already had been? Not sure. But all is fixed. http://www.sevenforums.com/sound-audio/136644-incorrect-sample-rate-playback.html#post1174624
  2. #12
    4,147
    What is "Sound Check"? Is that something in Windows Sound Device?
    Just for the record.
    In this context it is the Passmark SoundCheck software on this web site.
  3. #13
    4,147
    Just as a follow up for this,
    It seems we already had an FAQ question about the Vista sample rate issue. We added it maybe 4 years ago. But at the time we didn't know the root cause and so the FAQ didn't contain much detail. I'll update the SoundCheck FAQ with a link back to this forum post.
    I also went back and added a screen shot in case people can't find the setting.
  4. #14
    Jan 2011
    11
    Soloing1: That's good news - well done.
    Passmark: Thanks for updating the FAQ. I really think that the application needs to be updated though, AT LEAST so that it warns the user to check that the sample rate in the Windows audio settings matches that in SoundCheck. The issue here is that it is theoretically possible that the sample rates will not match, yet the program could run smoothly, and everything will sound ok. However, if the user is going to analyse the recordings, the results may reflect the quality (or lack thereof!!) of the Windows sample rate conversion, rather than the capabilities of the audio interface. Another problem is that when the sample rates do not match, this also causes the frequency response to be that of the LOWEST link in the chain. So, if the user enters 96000 into SoundCheck, but the Windows sample rate is 44100, the upper frequency will only be 22050Hz, when it should be 48kHz! The user may be totally unaware of all this. It is a BIG change in behaviour in Windows.
    It would also be great if you could support different audio APIs, such as DirectSound, ASIO, and there's some new one called "WSAPI". Of course, it would also be good if you could have SoundCheck change the sample rate (and bit depth) of the audio hardware to match the settings that the user enters into SoundCheck, or at least provide the OPTION for this.
    Greg.
  5. #15
    4,147
    We only make about $50 in sales per month for SoundCheck. Which means about $20 in profit before any support costs. So writing this post has blown the development budget on this product for this month
    A re-write of the software would mean 10 years or more of sales to recover the development costs. More profitable to leave the money in the bank, or invest in a more popular product.
    While it might not be ideal it is easier to change the setting in Windows as required.
  6. #16
    Jan 2011
    11
    Ok.
    Just one other thing.
    Your wording in the FAQ is not strong enough IMHO. The fact is that SoundCheck ALWAYS uses what you refer to as the "shared mode" settings. No matter what the user enters into SoundCheck, the hardware will be configured to however it is in the "shared mode" settings. It wasn't like this back on XP, but that's how it is now.
    I referred to this blog indirectly in my first post, but I want to refer to it directly now:
    http://blog.szynalski.com/2009/11/17/an-audiophiles-look-at-the-audio-stack-in-windows-vista-and-7/
    It has some very important information. (says basically what I have been saying, because that's where I got the information to begin with, however I think it's worth a read, nevertheless)
    Greg.
  7. #17
    Jan 2011
    11
    I just did a test to prove that my concern is valid.
    In Windows, I set the sample rate to 48000.
    In SoundCheck, I set the sample rate to be 44100.
    I then played a sine wave test tone, and viewed the spectrum of the input. (I used a loopback cable).
    The input had additional frequencies, other than the frequency of the test tone, DUE TO THE RESAMPLING OF WINDOWS.
    I then changed the sample rate in Windows to match SoundCheck.
    THE RESULT WAS A VERY CLEAN SPECTRUM.
    Btw, this is a nice program. It's good being able to view the spectrum in real time.
    Greg.
  8. #18
    Jan 2011
    11
    I repeated the test on Windows XP, and it STILL didn't change the sample rate of the hardware! Arrghh. (I used a USB interface for the test, because it has it's own control panel, and I can monitor the sample rate that it is set to).
    I then tried another sound card test program (a very popular one, it seems), and that did work the way I would want it to - it did change the sample rate of the hardware whenever I changed it in the program.
    So, I was wrong. It is not AS common on Windows XP for the hardware to be automatically configured to match the audio, as I thought it was.
    Greg.
  9. #19
    Jan 2011
    11
    Good news. It IS changing the hardware sample rate on Windows XP, but only as long as the requested rate is supported by the hardware. If it isn't, it seems to remain unchanged.
    I can only assume that I had entered one or more unsupported sample rates.
    It would be good if SoundCheck alerted the user if the requested rate was not supported by the hardware. I'm not saying that it should never allow unsupported rates, because it may be required to test the driver's ability to perform sample rate conversion.
    I've re-tested on Windows 7, and I can reaffirm that it NEVER changes the hardware rate. The hardware stays on the sample rate that is set in the Windows device advanced properties.
    Greg.
