Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Testlog Crashes
    286
    Default Testlog Crashes
    In some of the users' testlogs when a project name is clicked on the left window tree or double clicked on the right window, testlog will just crash and take the user back to windows. It happens every single time and with every single project. Tried uninstalling and reinstalling the program, clear the registry before reinstalls and it is still doing the same thing.
    Any help would be appreciated, thanks..
    286
    It would also show old projects that were no longer being used. Deleted a couple of times, cleared all registry entries pertaining to Testlog and Passmark, reinstalled, cleared user config file from the db drive and remade it and it seems to work now. Uninstall/reinstalls didn't do anything until the user file was reset by the way..
    Mar 2005
    913
    Which specific file did you remove, was it the "custom.dat" file? Which version were you using and did you upgrade recently to a newer version? If you'd like to email me my address is timr [at] passmark.com.
  4. #4
    Mar 2006
    6
    Not sure if this is the same problem, but today I am experiencing a runtime crash when accessing any project. This occurs whether I use a project I created, or the SampleDB that came with the app.
    I created a new user and clicked on a project and the app crashed without a runtime error.
    The runtime error is as follows:
    The instructions at "0x033c3fce" referenced memory at "0x03771c44". The memory could not be "read".
    Clicking OK then gave me the following:
    Runtime error 216 at 033C3FCE
    The app was working last night when I used it.
  5. #5
    Mar 2006
    6
    I un-installed the app, deleted all registry entries and re-installed, same problem. It will crash when clicking on any secondary entry in the left pane (even users). This even occurs with the sample database. Also, I'm currently the only person that has access to this database, and it worked for me Thursday evening (early early Friday morning). Nothing changed between the time it worked, and when it crashes.
  6. #6
    4,147
    What version of Testlog are you using? What O/S are you using? What version of Internet Explorer do you have? There have been a number of crash bug corrected during the last few months, so maybe your problem has already been fixed. See,
    http://www.testlog.com/support/ver_history.htm
  7. #7
    Mar 2006
    6
    I am using TestLog version 2.1
    With O/S: WinXP
    IE Version: 6.0
  8. #8
    4,147
    The current version of Testlog is V2.1 build 1013. See,
    What version are you using?
    There have been a number of crash bugs corrected during the last few months, so maybe your problem has already been fixed.
    Sorry to sound so repetitive, but we need this basic information to know what steps to take to investigate the problem (if required)
  9. #9
    Mar 2006
    6
    Build 1013, the only one available via the download page
    Further specifics on the IE version:
    Version: 6.0.2900.2180.xpsp_sp2_gdr.050301-1519
    Cipher Strength: 128-bit
    Product ID:55277-OEM-0011903-00102
    Update Version:; SP2;
    All patches from Windows Update have been applied.
    I even tried uninstalling the app, deleting the registry keys and installing on another drive. Same problem.
  10. #10
    4,147
    We have done some research on the crash today.
    We believe it is due to an infection by the SubSeven Trojan virus on your PC. Which also explains why it did work, but then suddenly stopped working. We don't think this is a problem with Testlog.
    The problem is detailed on Microsoft's web site.
    http://support.microsoft.com/?kbid=259279
    and many other web sites.
    http://www.google.com.au/search?q=%2...e+error+216%22
Similar Threads
  1. Video test Crashes Dell Laptop
    By Professoran in forum Other software
    Last Post: 07-12-2006, 01:44 AM
  2. TestLog reports
    By Anonymous in forum Testlog
    Last Post: 12-02-2005, 04:46 AM
  3. TestLog Question
    Last Post: 09-28-2005, 05:28 AM
  4. v5 crashes under Win 98 (SE)
    Last Post: 01-29-2005, 11:18 PM
  5. CPU Test Crashes System
    Last Post: 02-25-2004, 11:46 PM
