Network Timeout Errors
We are testing a new OEM platform and seeing up to 190 Network timeout errors on the Network using the default test period at 100% duty cycle. When running the test at 50% duty cycle we are seeing less, but not zero errors.
We are using a Nortel switch to windows 2003 R2 with a 3Ghz 8Cpu Xenon server as a target.
We feel this is excessive. Does this sound like a driver issue? Or is this test excessive for this configuration?
2 Software Versions:
Burnin Test ver. 5.3 Pro (1012) Win 32
Burnin Test ver. 6.0 Pro (1019) Win 32
Operating System:WindowsEmbedded POS ready 2009, Ver2.0, Service pack3
Processor: Intel Atom CPU N270 at 1.6Ghz
Memory: 1.60Ghz, 1GbRam
Chipset: Intel 945GSE
Network: Realtek RTL 8168D/8111D Family PCi-E GBE NIC
2 Network Drivers:
1- Realtek Ver. 5.720.327.2009
2- Realtek Ver. 5.754.310.2010
Please Help
Network timeouts are often caused by overloading.
So turn off all tests except the network test in BurnInTest.
Try using a cross over cable instead of a switch if you suspect the switch.
There is also the advanced network test option. See the User's Guide for details.
Time out errors
Yes we did, but we still receive excessive errors.
We used a crossover cable and we also ran a loopback test with no errors.
We noticed the errors mostly occur when running the Burnin test to a DHCP IP server.
Any Ideas? We also tried windows XP pro on the same machine, same driver but we still receive excessive errors.
Thanks, Mike
So you are testing between two machines with a switch in the middle, and get errors.
Then you remove the switch and replace the connection between the two machines with a direct (cross over) cable, and the errors disappear.
Thus it would seem sensible to blame the swtich or initial cabling.
If you are refering to the internal loop back test with the 127.0.0.1 IP address, then this isn't a good test of the hardware. It really just tests if the device driver is installed.
- You may not post replies
- You may not edit your posts
Forum Rules
