Results 1 to 2 of 2
Thread: Best GPS unit
    Nov 2009
    1
    Default Best GPS unit
    Which is the most compatible GPS setup with the wireless network strength mapping software.
    Mar 2005
    912
    As long as the GPS unit supports NMEA (min version 0183) and can be connected over a serial port (or virtual serial port in the case of USB units) it should be compatible with WirelessMon. There is a list of unit we have used in this thread http://www.passmark.com/forum/showthread.php?t=535
