Results 1 to 3 of 3
Thread: Uploading partial results?
    Aug 2009
    2
    Default Uploading partial results?
    Is it possible to upload partial results? I have a relatively new laptop with a Mobile Intel(R) 4 Series Express Chipset that performs better than many of the similarly spec'd notebooks. The only test that doesn't run is the last 3D test which requires AA 4x. Thanks for any help.
    I have the HP Pavilion dv4-1465dx (Special Edition)
    972 (Partial Result) [Using 64 bit version]
    System Summary
    Windows Vista (64-bit)
    Intel Core2 Duo T6500 @ 2.10GHz
    3998 MB RAM
    Mobile Intel(R) 4 Series Express Chipset Family
    298GB HDD
    CD-RW/DVDRW
    System Information
    System Name: MAD-NOTEBOOK
    Operating System: Windows Vista (64-bit)
    Motherboard Manufacturer: Compal
    Motherboard Model: 30F7
    Motherboard Version: 99.AA
    BIOS Manufacturer: Hewlett-Packard
    BIOS Version: F.42
    BIOS Release Date: 05/14/2009
    CPU Information
    Manufacturer: GenuineIntel
    Type: Intel Core2 Duo T6500 @ 2.10GHz
    Number of CPU's: 1
    Cores per CPU: 2
    Hyperthreading: Not capable
    Measured Speed: 2094.7 MHz
    Multiplier: 10X
    Bus Speed: 200Mhz
    Front Side Bus Speed: 200Mhz
    L1 Instruction Cache: 2 x 32 KB
    L1 Data Cache: 2 x 32 KB
    L2 Cache Size: 1 x 2 MB
    L3 Cache: (N/A)
    Memory Information
    Total Physical Memory: 3998 MB RAM
    Available Physical Memory: 2403 MB RAM
    Slot 1: DDR2, 2048MB, 800MHz
    Slot 2: DDR2, 2048MB, 800MHz
    Virtual Memory: C:\pagefile.sys (2048 MB)
    Disk Information
    Drive Letter (Number): C (Physical drive 0)
    Model Number: WDC WD3200BEVT-60ZCT1
    Disk Size (Free space): 286.4 GBytes (246.4 GBytes)
    Disk Cluster Size: 4 KBytes
    File System: NTFS
    Drive Letter (Number): D (Physical drive 0)
    Disk Size (Free space): 11.7 GBytes (1.9 GBytes)
    File System: NTFS
    Video Adapters
    Description: Mobile Intel(R) 4 Series Express Chipset Family
    Chip Type: Mobile Intel(R) 4 Series Express Chipset Family
    DAC Type: Internal
    Memory: 1807MB
    Video BIOS: Intel Video BIOS
    Driver Provider: Intel Corporation
    Driver Version: 7.15.10.1591
    Driver Date: 10-28-2008
    Monitor 1: 1280x800x32 60Hz (Primary monitor)
    4,147
    You can only upload complete sets of results.
    The Intel 4 Series Express chipset isn't a great performer, it is hard to imagine spectacular video performance from this machine.
    But I also have the feeling that these chipsets supported DirectX10, and as such must support x4 Anti Aliasing.
    Aug 2009
    2
    It very well could be a driver issue. I find it interesting that in the 2D tests, as well as CPU and Memory test for many submitted baselines (same CPU, Memory, OS), my machine performs better than machines with discrete Nvidia/ATI GPU solutions (better battery life too). Hopefully after HP updates the Intel graphic driver I'll be able to submit my results to your database. Thanks.
