Results 1 to 2 of 2
Thread: 2D graphic memory offset error on Quadro VGA FX1300
    Mar 2005
    1
    Default 2D graphic memory offset error on Quadro VGA FX1300
    I have several machines with the same card. After all when I have finish burintest v4.0 it shows me memory offset error on over few machines. Some how all this card having not problem to finish 3DMark at all. I got a problem to intepret this error message and also is this real failure.
    4,145
    There is not an error called, "memory offset". Maybe you mean "video memory corruption at offset....."?
    This is a common error.
    The video memory corruption is a real (but very minor) hardware fault that many video cards have. ATI investigated a similar issue for Acer around mid 2004. I don't know what the result was. NVIDIA also recently looked a this issue for some of their cards. The last I heard from their investigation was , "P4 cache coherency rules (and ordering rules) with regards to Write Combining" are most likely the problem.
    It is not a serious problem however. You will probably never notice a few of these corruptions in normal use.
Similar Threads
  1. 2D graphic test is black and white.
    By EKF in forum BurnInTest
    Last Post: 09-02-2005, 06:12 AM
  2. Burnintest video card total memory error?
    By genesis in forum BurnInTest
    Last Post: 05-06-2005, 12:06 AM
  3. strange memory error
    By Janto in forum BurnInTest
    Last Post: 12-12-2004, 11:00 PM
  4. weird graphic stats
    Last Post: 02-16-2004, 03:03 AM
