Generic test cases
I've been evaluating TestLog for the past few days, and been mostly satisfied with it. However, I'm trying to figure out if there is a way that I can set up generic test cases and assign them to different features. Currently, I set up test suites for different features in my software. Most of these features need to be tested exactly the same way - e.g., test the printing. Is there a way I can set up a master, generic test case that I can then assign to each test suite? That way, if I needed to make an update, I'd only need to change the test in one location.
I think the Recommended Config almost does this, but I'm already using that for different installations of my software. Is that my only option?
Thanks!
Currently there isn't any linking between test cases and project test cases that have been created from them, though this is something being considered for the next major version.
Tags for this Thread
- You may not post replies
- You may not edit your posts
Forum Rules
