Results 1 to 2 of 2
Thread: What are the settings of the basic disk test?
    May 2009
    1
    Default What are the settings of the basic disk test?
    I'm comparing some servers... and in virtually every instance of the advanced test 1 server has significantly better performance than the others. When using the basic disk test however, it is significantly slower.
    Can someone please tell me the settings used for the default "basic" disk test? I found this info on the forum in another thread, but based on the date I would guess it was for one of the older versions.
    "You might try the equivalent test settings in the Advanced disk test to see what it tells you about the speed during the test intervals. The settings equivalent to the Standard disk read test are:
    Test file directory: User AppData
    Test file 500MB
    Block size 16KB
    Standard Win32 API (Uncached)
    Asynchonous
    IO queue length of 20
    Test duration: 20 seconds
    Read/Write level: 100% reading, 0% writing
    Sequential/Random level: 100% sequential, 0% random"
    Thanks!
    Apr 2007
    212
    All Standard Tests:
    Block Size: 16384 Bytes
    Asynchronous
    IO Len: 20
    Read Test:
    File Size: 512 MB
    100% Read
    100% Sequential
    Write Test:
    File Size: 200 MB
    100% Write
    100% Sequential
    Random Test:
    File Size: 200 MB
    50/50 Read/Write
    100% Random
    Notes:
    On compressed volumes the sizes will be increased to 1.5x available memory or 3GB, whichever is smaller, in an attempt to avoid caching issues.
    Test duration can vary depending on preferences however the minimum is 20 seconds.
