Results 1 to 2 of 2
Thread: Link to test case from Web access test case list report
    Mar 2007
    8
    Default Link to test case from Web access test case list report
    We currently use the TestLog client software and are interested moving over to web access to testlog.
    We have very large test suites and one feature we really like in the client software is the ability to create a test case list report for a certain filter and then use that report as a list to easily open each test case in that list. This can be done in the client software as the test case list report links to the test case, and by clicking back we can get back to the list report. This allows us to easily traverse a complex set of test cases from a simple list.
    In the web access client all the same information is shown in the test case list report apart from the ID field is not a link to the relevant test case. It looks like all the relevant information is available and the html generated just needs a link added to ID column.
    Please let me know if you think this is a feature you might implement.
    Yvonne
    Mar 2005
    912
    This should be possible and we'll keep it in mind for the next update. The tricky part will be determining what to do with broken links if the test cases no longer exist, it should be possible to catch such an attempt and return the user back to the list report.
