Results 1 to 2 of 2
Thread: Burn-in 3.0 Fail to run with MS Error message:
    Oct 2004
    Nil
    1
    Default Burn-in 3.0 Fail to run with MS Error message:
    Burnin V3.0 can't run with Microsoft error message: Bit.exe has encountered an error and need to close, do you want to send this error to microsoft.
    Please advise me on the root cause of this issue and how do we solve it. Many thanks. [/img]
    4,147
    Firstly this is an old version of BurnInTest from a few years ago. See this page for a list of bug fixes and new features since the 3.0 release.
    http://www.passmark.com/products/bit_history.htm
    So you should check if the same problem is happening with the current release.
    This type of message can be caused by almost anything. If you still have the problem then you'll need to provide us with a lot more details.
    For example,
    - The full technical text of the error message.
    - Which O/S you are running
    - What hardware you have
    - What you were doing when the crash happened,
    etc..
    PassMark
Similar Threads
  1. 2D Tests Fail -- video memory corruption
    By 11murray in forum BurnInTest
    Last Post: 02-27-2009, 08:42 AM
  2. 3d and 2D tests together fail
    By HomerMan in forum BurnInTest
    Last Post: 09-04-2005, 02:55 AM
  3. Replies: 2
    Last Post: 03-17-2005, 10:54 PM
  4. Replies: 3
    Last Post: 12-17-2003, 03:39 AM
  5. Replies: 1
    Last Post: 01-23-2003, 11:12 PM
