sleeper test
i check the S1 mode and click the sleep button. 100 cycles is applied
system goes into standby
i need to press power button to wake it up, then the second cycle will continue.
is that correct? so the test doesn't run automatically?
If you have set a reasonable sleep duration (e.g. 60sec), and don't select the Sleep Forever option then the machine should wake itself up.
- You may not post replies
- You may not edit your posts
Forum Rules
