Results 1 to 2 of 2
Thread: Batch assign testers to test cases?
    Jan 2008
    7
    Default Batch assign testers to test cases?
    Is there anyway that I can select all project test cases in a project test suite and add testers to them in a batch edit?
    At the moment I can only add a tester by editing a test case at a time.
    Thanks,
    Vince
    Jan 2008
    7
    It's okay.
    I just figured it out.
    Selct the suite in the tree view.
    Highlight all test cases in the right pane view and click edit.
    Mulitple Test Case Edit window appears...
    Thanks anyway...
