Results 1 to 3 of 3
Thread: Production Line Automation
    Feb 2008
    2
    Default Production Line Automation
    Is there a way to override the "No Battery" prompt using BatteryMonitor 2.1 when auto-launching the application. We want the monitor to launch as a pre-test for BIT (5.3), but we do not want to require operator interaction for events where a battery is not available?
    4,141
    There is no way to override this message. But BatteryMon isn't a very useful application unless you have a battery system to monitor. So i am not clear why you are starting it on machines that don't have a battery system?
    Feb 2008
    2
    The layout requires me to run an automated script including BatteryMon. Whether a battery is present or not is unpredictable in my layout, so I was inquiring if there was a native option to simply disable the prompt. You have answered my question. I am using a simple prequisite WMI query to bypass this. Thanks
