hi all , please try to answer all the paragrafs described below
i've downloaded passmark then tested my pc
then i ran easy tune that comes with my Gigabyte
and overclocked my system ... now usually every part scored better
but only the h.d test showd reduced (73% less!!!!)
score from first test before overclocking and after .
1 ) so i was wondering maybe overclocking is doing allright with bus
(cpu mem agp) but bad for the drive ???
Rig:
2400+ athlon
2 X 256 DDR400Mhz
GeeforceII 64m sdram (not so much)
gigabyte GA..somthing
80g + 8mb cashe (wd800jb) western digital 7200RPM
2) the max overcloking that survived (didn't halt)
is 10% on top-of normal speed ... cpu is about 2260-2290Mhz instead of 1990 of normal speed
which is 147mhz bus speed instead of 133mhz
is that all u can get through over clocking
(that's stays around without halts)???
max speed tested>> scored around 220-230 points in over all test
(after overclocking !!!)
please tell me all u know
thanks in advance
R.banay
[/b]
