Results 1 to 2 of 2
Thread: Merging logfiles and create a common map
    Jul 2007
    2
    Default Merging logfiles and create a common map
    I looking for a method to merge logfiles as I may work with Netstumbler
    File > Merge: name.ns1
    Is there a way to merge several logfiles in order to create later on a common map?
    Thanks, Peter
    Mar 2005
    917
    No, there isn't a way to merge log/project files to create a combined signal map in WirelessMon.
