Results 1 to 2 of 2
Thread: weird graphic stats
    286
    Default weird graphic stats
    I got 117% worse simple graph,195% wors medium graph and 229% worse complex graph tests than I did for about 3 moths ago, the copm is 4 moths old. what can the great change come from??? all the other stats are the same or rose..
    4,147
    Something has changed in your system. Some things to check are,
    1/ Are you using the same video card device driver
    2/ Are you using the same version of DirectX
    3/ Are the settings in the video card device driver the same as before
    4/ Have you added a 2nd monitor so that you are now running dual monitors (this can decrease performance for all monitors)
    5/ Are you using software to switch your monitor between landscape and portrait mode. (This can disable hardware acceleration)
    6/ Are you running the same screen resolution and color depth
    PassMark
Similar Threads
  1. No stats for Intel pro/wireless 2100
    By Flier in forum WirelessMon
    Last Post: 07-01-2006, 01:52 PM
  2. Weird 3d Scores
    By thewibb in forum PerformanceTest
    Last Post: 03-02-2006, 05:13 AM
  3. 2D graphic test is black and white.
    By EKF in forum BurnInTest
    Last Post: 09-02-2005, 06:12 AM
  4. Replies: 1
    Last Post: 03-31-2005, 04:07 AM
